xplorer 400 1 spark then none
Old Apr 11, 2016 | 07:29 PM
  #21
If the stator plate wasn't removed, only the stator itself replaced timing should be ok.. Timing is at the 23.5 degree mark @3000 rpm.
Old Apr 11, 2016 | 08:05 PM
  #22
quadkiller8's Avatar
Update new cdi still same problem only thing left is flywheel stator was removed and replaced
Old Apr 11, 2016 | 08:17 PM
  #23
Then check the list I posted on models that will interchange and keep an eye out OR spring for a new one.They ain't cheap here. 369 bucks. Dirt Cheap Yamaha, Polaris, Suzuki & Kawasaki OEM Parts & Accessories – Cycle Parts Warehouse Ebay has a bunch,but again you take a chance.3084760 Polaris | eBay
NOS one here for 100 bucks..!! http://www.ebay.com/itm/Polaris-300-...hWiQZs&vxp=mtr You don't see these often...
Old Aug 1, 2016 | 12:07 AM
  #24
Brobrown77@gmail.com's Avatar
Default only one spark!
I have two Honda trx 125's that did the same thing after messing with them for days I finally just got a friend to pull me around the yard for about30 seconds and they both started working. Also did it to another 87 trx125
Originally Posted by brhoads6374
I have a 96 xplorer 400 that will not start I have tracked the problem down to the ignition system. When you hit the starter button and check the spark plug it will spark one time when the motor turns over then no more, when you hit the starter again you will get one spark again and then none. Has anyone had this problem with the 400 2 stroke before? I am thinking that it is in the stator but don't want to buy one if that is not the problem. Does anyone have a service manual with tests for the stator assembly to help diagnose the problem? I appreciate any help or advice.
Thanks,
Brian Rhoads
Old Aug 28, 2016 | 09:55 PM
  #25
Ok guys it's been awhile but stator is brand new everything ohms in specs new flywheel new cool and new Cdi even bought 2extra Cdi boxes with same luck kill switches isn't the problem and still no spark is there anything else it could be ? Even checked the etc switch and its good
Old Aug 29, 2016 | 03:59 AM
  #26
IF everything is new from the stator up and still no fire,then either a connection or ground problem,or if any of the electrical parts are aftermarket Chinese entirely possible one could be faulty straight out of the box. Just recheck the manuals resistance specs on the stator,coil along with grounds and all connections and hopefully you'll find the problem.
fordfaithful21
Dec 7, 2015 05:52 PM
Slagpolaris
Sep 5, 2015 09:41 PM
Jason Richards
Sep 4, 2015 06:17 PM
jeff mc
Dunes and Dune Machines
Sep 3, 2015 07:47 PM
