Sportsman Mods?
Old Apr 10, 2009 | 06:11 PM
Chevra's Avatar
Default Sportsman Mods?
I am looking at getting a bit more power out of my 2002 Sportsman 400. What can i put into it that i can install myself and not to much money? Can you get a chip or something for it? Im looking for anything at all here. Suggestions please.
Old Apr 10, 2009 | 06:27 PM
switzomatic's Avatar
Default Mods
Clutch kit and a pipe. You'll lose some top end clutching it but the low end torque you gain is well worth it. Not a big fan of chipping but other listers may have more feedback on that.
Old Apr 10, 2009 | 06:38 PM
Polaris Sportsman 450's Avatar
I have a 2006 Polaris sportsman 450 and I was told to put a K&N air filter on it and run AMS OIL. they also said to put a new fuel filter and sparkplug i would put the NGK Iridium IX Spark Plugs. i would also put mudlite tires on your ATV. They make a big difference. i wouldnt go and larger than a 25 tire.
Old Apr 10, 2009 | 06:48 PM
Chevra's Avatar
Ya i was thinking about the K&N filter, but wasnt sure how much of a difference that would make. But im guessing that it does work? And a pipe would be nice also, i just need to find where i can get one. I already put on some mud bug tires which helped out so much, i can go through anything now. The stock tires would just dig down till u were hung up, these dig and dig no matter what.
Old Apr 10, 2009 | 06:52 PM
http://www.partsforatvs.com/polaris/sportsman/power.asp they should have the pipe you are looking for. I have never put one on a polaris Sportsman But i know when you pipe a snowmobile it make a big difference.
Old Apr 11, 2009 | 11:15 AM
Killjoy's Avatar
+1
I have a 2000 SP500 and run stock except for NGK Iridium plug, K&N air filter, Mobil 1 oil and oil filter, 25" ITP Mudlite XTRs. The air filter is really a no-brainer in that it's pretty cheap, plus you no longer have to buy a new filter every time you do a tune up. Was there a lot of performance difference? No, not really.
I wouldn't go with larger tires on anything less than a 700cc quad (26" maybe, but certainly not 27"s). I stuck with 25"s and am happy I did. It would be a different story for the newer quads that are geared to run 26"s OEM. 25 --> 27 on a 400c motor with gearing for 25's is bad news... unless you're willing to upgrade the gearing/trans too.
I haven't done a pipe simply because 1) they're expensive 2) I doubt I'd see $200-300 in performance 3) to do it right, the carb probably should be re-jetted 4) the MI DNR can be a PITA on decibel levels.
Maybe look at a NOS kit?
Old Apr 11, 2009 | 11:30 AM
TLC's Avatar
TLC
The 2002 have no ECM brain box so the chip thing is out of the picture. Pipe and clutch kit is the norm.
Cole Hadden
Jun 15, 2025 09:05 AM
Cantbuytime
Aug 17, 2015 06:33 PM
Bergmann
Aug 13, 2015 03:51 PM
chuck1177
Aug 11, 2015 03:22 PM
Jul 22, 2015 05:00 AM
