Lift Kit problem
Old Apr 21, 2009 | 07:30 PM
Magnum-X's Avatar
Well I figured it out. I initially thought it was the left cv joint. So I tore it all down and check it out everything looked good so I put it back together and gave it a try. moved the machine 15' still doing it. so I back it back in and put it back on the lift. Started the bike and tried it in 2 wheel drive(on the lift) everything looked normal rear wheels engaged. Shifted into AWD and looked across at the left front wheel it looked good also, it was engaged. It was then that I looked down at the right wheel which seemed to be turning much slower. So I decided to see if I could stop the wheel with my hand. Well not only could I stop it, I could spin it backwards. So I got busy and stripped down the right shaft and what I found wasn't pretty. The spline on the end of the shaft going into the cv joint was virtually destroyed. then I got looking at the cv joint itself. 2 ball bearings where laying in the grease in the bottom and the cage was busted up bad. Needless to say I have a new shaft assembly on order and should have it back in service soon.
By the way I had a hell of a time getting the shaft out until I used the slide hammer method. I will take some photos of the method I came up with for attaching the slide hammer to the shaft. (it worked like a charm.)
Old Apr 21, 2009 | 08:27 PM
rockout's Avatar
just wondering, but i think you might have dislodged the cv when you installed the lift and when you rode it, it tore the splines up. i put a lift on my ac and could see how it could happen. when i had my polaris apart to try to repair the lower a arm bushings, i ended up dislodging one of the outer cv joints and didn't notice it until i went to put it back together and the front end was hanging up. i had a torn boot on the other side, so i decided to replace them all. when i tore it down, found the cv came apart inside the boot causing the front end to hand up. again, just a thought on the cause.
Old Apr 21, 2009 | 08:57 PM
Magnum-X's Avatar
I agree with you rockout. I also pulled out on the top of the strut the slightest bit to get the spacer on. I have no doubt I pulled the cv joint loose when I did this.
Old Dec 3, 2019 | 05:35 AM
Mikefoye's Avatar
Default Always strap
Whenever you work on your quad with the front tire off and strut off always strap it up to your rack or it will pull out . If it does just simply line up the splines and push no biggie
ogio117
Polaris Side by Sides
Apr 29, 2019 03:14 PM
ScopeZ_
Jul 28, 2015 01:44 AM
Ty64
Technical and How-To Articles
Jul 25, 2015 02:02 PM
hondarider1234
Jul 21, 2015 11:53 PM
