850 With 30" zilla's
Old May 6, 2009 | 07:51 PM
  #21
HIGHOCTANE's Avatar
Originally Posted by RticKwad
Rutcutter,
Is there any issues with these new XPs like its former Sportsman with the front sag issue needing 1-2" spacers or replacing stock springs for the front? Just asking since you are now running 30" tires. I haven't heard any chatter yet
As another incentive perhaps to GO XP! b/c I don't like how my center of gravity is off with the front raised, I had to compensate a little with raising the rear stock setting to the highest to prevent rear squatting issues.
Thx,
R'
Unlike the older Sportsmans the front shocks are adjustable,so if you feel they are too soft you can turn them up. Like the old Sportsmans the front is softer than the rear for a given setting...
Even so the highest I have had the front is the 3nd notch( of 5),2 up from stock, and that is for fast trail riding with a winch and front storage box to reduce the dive up front. The rear has never been higher than the 2nd notch(of 5),1 up from stock..which is really only needed to reduce squat when towing loads with real heavy tongue weights,although it isn't bad on the lowest setting.
Old May 6, 2009 | 09:40 PM
  #22
DavidXP's Avatar
i wonder if the 30's would have a rubbing issue i know my 27's rub and i believe that H.O said he had the same issue just up front on that fin like thing?!
Old May 6, 2009 | 09:48 PM
  #23
smoothbassman01's Avatar
Those are really sweet! You don't have issues with the tires scrubbing the rear sway bar? Heard that could be an issue with larger tires.
Quadzilla Heritage
Sep 25, 2015 01:39 PM
Alex G.
Sep 19, 2015 06:34 PM
Folkzilla
Aug 21, 2015 12:36 PM
coolguy420
Jul 10, 2015 01:17 AM
mtecate4g
Aug 28, 2001 12:50 AM
