Have Had Enough!!!!!!!!!!!
Old May 14, 2009 | 09:34 PM
kbb7483's Avatar
Default Have Had Enough!!!!!!!!!!!
A few months ago purchased a 2004 Sportsman 700. I knew it was broke when i bought it spun bearing on the crankshaft SO I THOUGHT. Since then have rebuilt motor, replaced winch, new brakes, new ball joints, replaced front axle, replaced front differential due to cracked ring gear, replaced rear drive shaft, and now finding that the drive clutch is bad. Found ebs hub siezed and cracks on the bell. Now the question i have is the clutch on a sportsman 500 the same as the 700 with just the weights and spring being the difference. Have put way to much money in just want to go ride.
Old May 14, 2009 | 09:39 PM
DarrenWS6's Avatar
Sounds rough.. My EBS just went on me, the secondary was seized and not closing, took it apart, $30 and the polaris shop put a new spring in it and it works great.
Old May 15, 2009 | 05:19 AM
stendori's Avatar
Super Quad Patrol
I'm watching you!
it should be the same as long as its an ebs clutch. what year is the 500 from?
Old May 15, 2009 | 07:16 AM
kbb7483's Avatar
I know the little research i have done is that a 2004 clutch are all the same other than the spring and weights. The 500 clutch is also 2004
Old May 15, 2009 | 07:20 AM
kbb7483's Avatar
Smile
I'm sorrry i did not let you know the worst part about my 700 it has 413miles on it. haha
Old May 15, 2009 | 07:34 AM
Spdecat's Avatar
I'm sorry i did not let you know the worst part about my 700 it has 413miles on it. haha
Sounds like the previous owner drove the sh*t out of it as with only 413 miles it should be mint and problem free .
Old May 15, 2009 | 07:46 AM
kbb7483's Avatar
"Should be" thats the key word
Old May 15, 2009 | 08:39 AM
TLC's Avatar
TLC
The good thing is a ATV with a spun crack bearing sells for $500 at most right,? so if you pour money into it your still ahaed I hope.
