Rotopax Fuel Pack
Old May 17, 2009 | 03:31 PM
700 sportsman's Avatar
Default Rotopax Fuel Pack
Hey guys I got my fuel pack last week, and know I'm tryin to come up with some sort of mount system,
Do you have to drill holes in the rack for the mounts from Rotopax
Also what other custom mounts have you guys made
P.S. It's goin on my 07 700
Old May 17, 2009 | 10:31 PM
RticKwad's Avatar
Runs Stealth!
A friend of mine made a steel piece for his front cargo rack (lid). Then he mounts them on there. I wish I had a pic for it. I need to get those dimensions and have one made myself.
Cheers,
R'
Old May 18, 2009 | 07:27 PM
I made up a set of aluminum mounts for mine, I have the packs that hook together, so I took them apart and mounted one on each side of the rack
I will get some pics tommorrow
Old May 18, 2009 | 10:53 PM
TheATVSuperStore.com's Avatar
Former Sponsor
Here is what I did. Took a plate and cut it to the size of the metal bars. I drilled 4 holes total into the metal bars that are on the rack & mount the plate with 4 bolts and lock nuts. I can take better quality pics tomorrow if needed. Just came back from a 200 mile trip and it worked perfectly. Just click on the web album below.
Fuel Pack Mount
Old May 18, 2009 | 11:13 PM
chuck_raduenz's Avatar
nice mounts thor.
Old May 18, 2009 | 11:52 PM
MickJP's Avatar
Attach the mounts to an aluminium plate like in Mr Thors picture above, but instead of drilling new holes, just use the existing ones for the metal tie-down bars, and replace the bolts with longer ones and spacers.
It's a cleaner job if you change your mind later.
Old May 19, 2009 | 09:09 AM
Former Sponsor
Now thats a great idea that I did not think of MickJp using the existing blots! Smart!!
Old May 19, 2009 | 10:03 AM
switzomatic's Avatar
Default Fuel pack
I attached heavy duty double sided strips of velcro with zip ties to each corner of the rails on the front box. Looped the velcro and attached on the corners of the fuel pack. Also have a piece of memory foam under it to keep it from sliding around/getting beat up. Been working flawlessly for almost five years. Good alternative if you do not want to drill holes in your box for the Rotopax mounts. Be nice if they came out with a mount that was compatible with the popo set-up.
Old May 19, 2009 | 10:06 AM
Default Mount
That mount of Thor's is SWEET! When I upgrade to the new style fuel pack someday(my old one still works great) I'm definitely going that route.
PrairieDog126
Sep 12, 2015 06:53 PM
gogogo
3) General Discussions..
Sep 8, 2015 08:49 PM
MikeyBoyesq
Sep 7, 2015 10:44 PM
Elkaholic
Sep 6, 2015 02:44 PM
toonces
Sep 5, 2015 01:14 PM
