850xp wheel bearing problem?
Has anyone else had any problems with the wheel bearings i think mine are getting bad.I am starting to get a lot of feedback through the bars i have checked everything on the front end and there seems to be play in the hubs when you grab the front wheels and pull on them you can here a clunking sound.
Also forgot to mention mine does not have eps,it has 550 miles on it.what i am feeling was never there before and it feels **** i feel every little choppy bump being transfered through the bars.It used to be the smoothest atv i have ever ridden now it sucks. i have been trying to get a hold of my dealer to have it looked at.
In addition to the ball joints also look at the tie-rod ends and A-arm bushings. For the a-arm bushings..With the machine jacked up(securly) set the parking brake and try to spin the tires back and forth against the brakes resistance,in other words try to roll them. See how much they rock while watching the arms. Since the brakes are locked movement will come from a-arm bushings or ball joints.
Tie rod ends..have some one rock the bars while you watch the ends.
Rooky
10
06-23-2015 09:35 PM
