Polaris 350L
Old May 20, 2009 | 09:17 PM
Moldy oldie's Avatar
Unhappy Polaris 350L
I have a 93 350 L that quits when going down hill like it is out of gas.It will start after sitting 30 seconds. I need help. any Ideas please.
Old May 20, 2009 | 09:26 PM
war1ock's Avatar
may need a carb adjustment. It sounds like no gas is making it on grade. Not quite sure though sorry.
Old May 21, 2009 | 05:39 AM
stendori's Avatar
Super Quad Patrol
I'm watching you!
check the float bowl for the float being out of adjustment.
Old May 21, 2009 | 05:52 AM
ftwflh's Avatar
Also check the vent line on the tank
Old May 21, 2009 | 08:40 AM
Rebuilt the carb,checked the vent, possible setting on carb we are running about 3000' it will also stop if going over mogils.
Old May 21, 2009 | 08:07 PM
93 350's and 94 400L engines had a problem of gas dumping into engine lowering the carb bowl level because of vibration. Would do it on downhill and long runs,would die down and pick back up.On the 94 400 an update rubber support was added to transmission to help steady the carb,solved a lot of problems. The kit wont fit the 350 because the trans is different,BUT you might try to add a rubber support of some type under the carb and see if it helps. Good luck OPT
Old May 22, 2009 | 05:24 AM
stendori's Avatar
Super Quad Patrol
I'm watching you!
wow, triple post. that doesnt happend very often to old member. lol
Ramman1
Aug 11, 2022 01:53 PM
NoJoke
Aug 9, 2015 12:39 PM
338 lap mag
Technical and How-To Articles
Aug 2, 2015 03:57 AM
Polaris Side by Sides
Jul 30, 2015 12:14 PM
cornermike
Jul 30, 2015 06:37 AM
