Recommended tools etc....?
My list:
50' of 1/2" rope (or 2500 lb. rated mule tape)
Socket and open end wrench sets (1/4" to 1 1/4" in my case, but metric might rule here)
Flat tire "quick repair" kit (plug and CO2 gear)
Winch
At least one other machine and rider
I could be way off base with this, but methinks the above ideas are essential, especially if you ride in the back country a lot (I do).
Just my humble opinion: You need to be prepared enough to get off the trail and back to serious help on your own. If you are not, you are likely to end up regretting it one day.
CIAO
Winch
CIAO
i have a like a plastic yellow tool box filled with zip ties and vise grips and all types of tools and junk.. its all stuffed in there.. and i really would like to bring it on the trail but i dont wanna listen to that **** bangin around all day on the trail.. i was thinking off maybe taking a towel and stuffing it in there to muffle it.. not a bad idear..
Thanks folks. Appreciate the inputs. My biggest challenge is being able to carry what I may need without taking up too much space. I'm in the process of assembling a survival bag that I can take with me pretty much anytime and not limit it's use to the ATV. I'm using a Maxpedition bag and it should work pretty well for hikes, ATV's, and Jeeping. In any case, I appreciate the inputs.
Cheers,
cc
Cheers,
cc
#15
Flat tire kit, small air compressor, ratchet strap or hand winch-come along-to reset bead on tire, small shovel, small saw, toilet paper, bug repellant, flare gun w/flares, space blanket,hand signal mirror, headband flashlight, rain gear,warm coat, first aid kit,GMRS radio,cell phone, food,water, tarp and rope to make emergency shelter or repairs on, water purification kit,snake bite kit, Spot emergency hailer, duct tape, Wet ones wipes, boat anchor for winching post when none available, extra radiator hose with clamps, spare engine / trans fluid, antifreeze, GPS, extra fuel.
Pick and choose as needed, or carry all as needed. And the #1 thing to do-Tell someone where you're going, who you're with, and when you will return.
My.02
My.02
kampswas
Sep 23, 2015 05:05 AM
Jersey General
1) Engine problems..
Sep 13, 2015 01:05 PM
