where do i drain my transmission/gearcase oil?
Old Jun 28, 2009 | 10:43 AM
element7878's Avatar
Default where do i drain my transmission/gearcase oil?
I have a 2000 polaris trailboss and am trying to find out where to drain the old oil out...Any information would help..thanks
Old Jun 28, 2009 | 12:01 PM
ftwflh's Avatar
There is a bolt on the bottom side of the gearcase that is jammed against the frame.run the in and take the bolt that is screws into out of the grearcase.
Old Jul 3, 2009 | 02:06 PM
Default In regards to polaris trailboss fluids
Hey man thanks a lot, i found the drain plug and changed it out. However,
Does anyone know of any other fluids that may need to be changed on my atv? Besides the Oil, tranny oil, and brake fluid? Are these the only three on my atv? My atv begins to make a small noise around 20mph..It only makes it when you hit the gas tho...If i am going 30-40 mph and then let off the gas, it will not make the noise as it is rolling and slowing down, but if i hit the gas again it will begin to make it again..Im not sure if it is something that is low on fluid, or something is just rubbing as i hit the gas at these speeds.. Any help is appreciated, thanks
Old Jul 3, 2009 | 05:15 PM
ftwflh's Avatar
Sounds like the chain rubbing the guide
Old Jul 5, 2009 | 12:39 PM
well i was thinking it was possibly the chain guide also, but i took it completely off and rode and it still makes the noise..
Old Jul 5, 2009 | 04:12 PM
ftwflh's Avatar
how do the sprockets look
ReconBayou
Oct 31, 2022 05:37 PM
Alex G.
Sep 11, 2017 11:38 PM
wrencher82
Sep 30, 2015 04:27 AM
wrencher82
Sep 28, 2015 10:02 PM
wrencher82
Sep 24, 2015 03:39 PM
