leaking cv boot
Old Jul 4, 2009 | 02:01 PM
taylormade1ca's Avatar
Default leaking cv boot
hey there i have a 08 800 and have a leaking cv boot .it is leaking under the small band.i can turn the bottom of the boot a little bit back and forth.so i was wondering should i just reband the small one tighter .or should i take both off slide the boot down clean out and regrease and reband.i really dont want to take the axle out just do it on the machine can this be done? thanks for the help.
Old Jul 4, 2009 | 04:13 PM
weedy's Avatar
'5 minutes worth of planning equals 30 minutes of execution'
As long as you have not been in any water you should be OK with just rebanding. Iy you have been in water be sure to take apart, clean, regrease and install new boot and clamps. I recomend the stock boot because they are much easier because they fit better and have better clamps.
Old Jul 4, 2009 | 05:33 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
well only you can really tell if you have been in any water/mud or not. if theres any doubt what so ever, do your self a favor and TAKE IT APART and regrease it! its way cheaper then replacing the cv joint when the dirt/water ruins the cv joint. imo.
Old Jul 4, 2009 | 11:34 PM
switzomatic's Avatar
Default CV
Ditto! Save yourself some heartache and make sure it is cleaned/regreased.
Old Jul 4, 2009 | 11:51 PM
The Kid's Avatar
exmotocrosser
Sep 13, 2019 06:12 AM
Alex G.
Sep 11, 2017 11:38 PM
wrencher82
Sep 24, 2015 03:39 PM
95scramblerruben1033
Sep 23, 2015 06:29 PM
