2005 polaris 700 efi fuel problem
Old Aug 4, 2009 | 08:51 AM
02magnum500's Avatar
Gets his share of deer.
Crooked Step, you show that you have a 2004 700 EFI, I dindnt think EFI was till 2005?
Old Aug 4, 2009 | 10:24 AM
quickbiscuit's Avatar
G&K, did you ever find the cause of your problem?
Old Aug 4, 2009 | 03:06 PM
duffus's Avatar
Originally Posted by CROOKED STEP
I think my fourwheeler is doing the same thing as yours. Mine might run for 7 or 8 miles then start cutting out and not takeing fuel popping and carrying on then i can let it set for 5 to 10 min and then it runs fine. Might run the rest of day or like yesterday mess up again in a few min. Just repaced the fuel filter and i checked my fuel pressure when it was running good and i had 39 pounds. Im going to take fuel pump out of tank and see if it has a sock filter on it. Please let me know if you fix your problem
exactly what mine was doing last year-- had to replace the fuel pump (fuel tank and all).
Old Aug 4, 2009 | 09:08 PM
JCDEYO25's Avatar
Similar to a recent post......I'd check the throttle body for grime build up.....Pull the rubber boot to the TB and look into the TB for buildup....Open and close the butterfly and clean the TB and the butterfly with 3M Throttle Plate cleaner with a Q tip.....Let us know....
John
Old Aug 4, 2009 | 09:32 PM
  #15
CROOKED STEP's Avatar
yes they made a 700 EFI in 2004 that was the first year they had it out it might have been a 2004.5
Old Aug 5, 2009 | 08:16 AM
  #16
EFF_Rubicon's Avatar
yes it is an 04.5 i have one also i try to keep some
seafoam on hand at all times to make sure all my bikes run good
Old Aug 5, 2009 | 09:12 AM
  #17
Ruggo's Avatar
I had a similar problem with me race car ..... after weeks of trouble and expense I found the problem was in the tank at the fuel pickup. There was crap in the tank and after the car would round for 5 or 10 minutes enough crap would get on the pickups screen to nearly stop the flow. Shut it off and move it around all the crap would drop off, then start it an same thing would happen. Also the filters on EFI are very fine, not sure on the microns but I also had an issue with Top End Lube we were adding to the Methanol to take the edge off was thick enough even with low concentration that it would clog the fine filters just before the injectors.
hoopduerr
Jun 10, 2015 03:00 PM
hoopduerr
Jun 2, 2015 09:01 AM
hoopduerr
Jun 1, 2015 08:22 PM
May 27, 2015 11:15 AM
trick33
Feb 10, 2001 08:27 PM
