cv boot pliers
Old Jul 8, 2009 | 12:04 AM
eggenz7's Avatar
i just replaced some on a 09 500 ho..those were a pain. the small end we could get on with a modified pair of needle nose but the big end we had to take back to the dealer and he even had hell getting it on. instead of the original type that you pull till tight then cut excess these clip together and are none adjustable.
Old Jul 8, 2009 | 11:54 AM
jethrob's Avatar
Originally Posted by chuck_raduenz
i have to agree with weedy. ill stick with polaris bots. i got a set from i think it was amarican cv. they needed a banding tool. so i got that. i fixed my boots. got then tight as i could. installed the cv axel. drove it around. and awhile later the cv boots started to leak around the large band. the after market boots i got also seemed great when i got them. but after while they seemed pretty cheazzy. i cant really exsplane it. but ill never get aftermarket ones. ill stick with polaris ones as the fit, and they seal.
imo
The only way I can see you having a leak around your seal would be if you did not get your clamp tight. It's a tougher rubber so you need to get a good tight band around it. The aftermarket ones I got from American CV are of superior construction.
Alex G.
Sep 11, 2017 11:38 PM
95scramblerruben1033
Sep 23, 2015 06:29 PM
jankerstien
Sep 21, 2015 03:09 AM
Nosniborpapa
Sep 12, 2015 05:54 PM
