01 scrambler belt ripping question
Old Jul 11, 2009 | 12:14 AM
psychoracing's Avatar
yeah I dont have a local polaris shop close to me, There may be one in Orlando, I will look more into it though, is it hard to disassemble the secondary ? special tools and such ?
Old Jul 11, 2009 | 02:57 AM
scramblerXrated's Avatar
a good set of snap ring expanders and a buddy, youll have that thing apart in no time. you should definitely reference a service manual before you tackle that. that way u know the way it comes apart, and the way it needs to be re assembled properly,
X
Old Jul 11, 2009 | 07:32 AM
Ok cool, thank you ! After you pull the snap ring is it under alot of pressure or is it at the end of its travel ?
Old Jul 11, 2009 | 11:29 AM
theres some pressure there, but its not going to explode on you.
X
Old Jul 11, 2009 | 12:50 PM
  #15
Well I tackled the job, look what I found....... Whats next ?
Old Jul 11, 2009 | 12:58 PM
  #16
wow, thats in bad shape. well just like i thought, the spring broke due to being preloaded the wrong way. you can tell by the last coil sticking out from the rest. they should all be uniform coils.
a new helix, spring and buttons should fix it right up. but, its probably cheaper to find a good used clutch on ebay or something.
X
Old Jul 11, 2009 | 01:04 PM
  #17
I am taking it that spring is not stock then ? where would I find one of those or should I just use the one that comes in the clutch I get from ebay or wherever ? and this is most likely why it was eating the belts then ??? I really appriciate your help buddy, I owe you a few beers !!
Old Jul 11, 2009 | 01:54 PM
  #18
What are the buttons you speak of? it looks like just a helix is 40$ so i might as well get the whole thing, but can I use the spring that comes with it or do I have to get the matching orange spring ? I looked on ebay for the orange spring and cant seem to locate it.
Old Jul 11, 2009 | 02:32 PM
  #19
im sure whatever spring you can get will be fine. but if you check: https://www.erlandsonperformance.com...=atvpolsprings
they have the orange spring if your really wanting to put it the way it was. $19.95
the buttons are little plastic pieces that the helix ramps ride on. yours are completely gone. all thats left is the 3 little screws. they are only $10 for the set of 3.
X
Old Jul 11, 2009 | 04:37 PM
  #20
Cool, I am waiting to hear back from a guy to see if he has one and if not then I will hit ebay. hopefully this was the problem all along. if not I dont know what else to do.
