xplorer charging system maybe?
Old Jul 12, 2009 | 05:54 PM
pipelinewelder20's Avatar
Thumbs down xplorer charging system maybe?
ok this is the second time it has done this my 96 xplorer 400 after about an hour of nite time trail riding the starter wont work i have to pull start it the rest of thenight, and the light go dim when at an idle and the dont light up till the engine is revved up, then after about 2 0r 3 hours of trail riding i can take it home park and the next morning everything is fine again fire's right up with the electric starter and the lights are bright does anyone have any ideas on what this could be
Old Jul 12, 2009 | 06:53 PM
You might want to have your battery load tested if terminals are tight and fluid level is good. Could just be time for a new one. Battery could be just sulfating from age.
With lights dimming and brightening,battery may not be able to take full charge from reg/rectifier. But check connections first,if not tight can do the same thing and not completely charge? If battery load tests ok,might check into reg/rectifier. Plus are you running stock lights or add ons also? Could make a difference
Old Jul 12, 2009 | 08:56 PM
thanx for the reply, no just running stock lights, and battery is about 9 months old, but i will load test it and proceed from there , do you know what volts the charging sytem should carry at what rpm
Old Jul 12, 2009 | 10:01 PM
DitchDigger's Avatar
I know it doesn't start charging until a certian rpm, something like 3000. Mine stopped charging this winter, after hours of tracing wires I found a bad connection in the main harness plug inside the headlight pod. I couldn't believe how much corrosion all the connections had on them. I would check all the connections on your charging circuit and make sure they are good. Add some dielectric grease while you have it apart. A bad connection can get worse when heat is added, could be increasing the resistance on the charging circuit.
Old Jul 13, 2009 | 03:23 PM
02magnum500's Avatar
Gets his share of deer.
With it reved up a bit the output should be 13-15VDC. Put a multimeter on your battery when the engine is reving a bit. Battery should be 12.6VDC when machine is off. At idle it should be around 13VDC at the battery. Just a few #'s.
Old Jul 14, 2009 | 06:30 PM
its carrying about 14.6 volts at just over 1/4 throttle and it has a new starter on it any idea's
Old Jul 15, 2009 | 07:12 AM
Kerbbirds's Avatar
Must be the battery if its charging and all connections are good and clean, Ive started buying gel filled batteries and have had good luck with them so far.
Old Jul 15, 2009 | 07:45 PM
can u get them at the local parts store or do you order them off the net
ReconBayou
Oct 31, 2022 05:37 PM
r1pilot83
Utility ATVs
15
Nov 25, 2019 11:39 PM
Oct 10, 2015 10:20 AM
rockinkgin
Sep 25, 2015 01:52 PM
