xplorer death wobble
Old Jul 19, 2009 | 05:29 PM
pipelinewelder20's Avatar
Exclamation xplorer death wobble
at about 30 mph and above my steering wheel shakes back and forth really badly, it doesnt do it at lower speeds , its got all new bearings ball joints and tie rod ends in the front end, i jacked it up and couldnt find anything loose or wore, is this a common problem on the older xplorer 400 (its a 96) or should i look for somethins else
Old Jul 19, 2009 | 05:55 PM
weedy's Avatar
'5 minutes worth of planning equals 30 minutes of execution'
Check the toe alignment. How old are the tires? Are they severely out od balalnce?
Old Jul 19, 2009 | 06:38 PM
they are new tires and i did slime all of them i thought as a prevantive measure but after checking i think i have a loose bearing too and they have less than 25 miles on them, i am thinkin the slime needs to come out of there, and how do you tighten the wheel bearings on this machine
Old Jan 9, 2010 | 10:42 PM
RideReno's Avatar
I bet the slime has all went to one side of the tires, or is not spread evenly inside the tires causing bad vibes at higher speeds. I had this happen on a pickup I had.
MeadowlarkFarm
Nov 27, 2019 08:40 PM
r1pilot83
Utility ATVs
15
Nov 25, 2019 11:39 PM
rockinkgin
Sep 25, 2015 01:52 PM
MeadowlarkFarm
Sep 9, 2015 03:08 AM
