Battery problem? Weird electrical trouble?
Old Jul 28, 2009 | 10:26 AM
kaarde's Avatar
Unhappy Battery problem? Weird electrical trouble?
Firstly, hi to everyone, this is my first post around here
I've got a 2008 sportsman 500 EFI and it started doing some weird stuff for the past month or so. The dealer took a look at it and said that everything was fine. So that was 100 bucks not well spent!
My problem is that one day i was riding and my popo just died on me. No more power whatsoever. The display turned off and the motor too. Switched it off, told myself I should've stick with computers, switched it back on and the power came back on. It started fine and the rest of the day was great. I thought it was only a glicth. But then a couple of days later, I went to start it up but when i turned the key there was no power. Turned the key, put the power switch to off then on, turned the key.....nothing.....oh wait.....it came alive. Started fine so i went riding and it died on me there too. It did the same thing as earlier, switched off then on wait a couple seconds and then it powers on. I thought it was the battery so i charged it but there is no differance. I'm no mechanic so if anyone as an idea about where i could start looking and as some basic testing that i could perform i'd be more than happy
Old Jul 28, 2009 | 10:39 AM
Lugnut03's Avatar
Check all of your connections on the battery including the groundwire...sounds like a grounding issue to me....
Old Jul 28, 2009 | 08:04 PM
kaarde's Avatar
Ok, thanks for the repply. I'll start with that and where it gets me.
thank you very much
ripperray
Oct 10, 2023 02:42 AM
Mattius
Jul 11, 2015 10:44 PM
leenover
Jun 5, 2015 09:50 PM
sae156
1) Engine problems..
Jun 3, 2015 01:45 PM
Dpearson03
Utility ATVs
May 29, 2015 04:51 AM
