92 250 trail boss
i just put in new crank seals. the wheeler starts fine. but once it starts it goes into high rev. now if cover the intake the wheel idles fine. where is the bike getting air from. maybe the intake boot, not sure.
Still no help yet.
the wheeler will start fine without the choke. once it starts it goes right into high rev. now if i put my hand over the intake and almost cover it all. it will idle. i have pulled the carb and cleaned it.
i would check the rubber boot the the carb goes into on the cylinder. those things are notorious for getting cracks in em. while the engine is running and your hand is over the intake, spary some carb cleaner or starting fliud around that boot..if it revs then there is a leak.
FIXED!
well after doing a better inspection and instead of guessing. i pulled the air box off to see if the slide was closing. Well it wasn't. seems that the oiler cable had been cut off of the throttle cable and was binding up the whole thing. so i cut that apart and removed the old cable and taped it up and what do you know it actually runs,starts,idles and all the good stuff. Was really late last night and i couldnt think for ****.
oliveiracarlos
19
Nov 11, 2015 05:49 AM
craacker
Sep 9, 2015 04:32 AM
Elkaholic
Sep 6, 2015 02:44 PM
