Carb Still leaking??? HELP
Old Aug 6, 2009 | 07:30 PM
Ragelite's Avatar
New boot is on and carb is STILL leaking. Pulled the plugs and they are BURNT, so black its not even funny. Damm.
Old Aug 10, 2009 | 07:13 PM
Ragelite's Avatar
So the boot wasnt the prob, I checked the float levels and its bang on. So at 5000 RPM's its still spittin gas out the overflow tube..... wow 2 weeks of working on it and nothing. lol who woulda thought eh?
Old Aug 13, 2009 | 09:10 AM
Ragelite's Avatar
So last night I was playing around with a few things I saw that the motor mount beside the carb was moving a ton so I put a bar under the carb to stop it from shaking so much and it stop spitting fuel out the overflow tube. Does this make sense to anyone out there?
Old Aug 13, 2009 | 11:23 AM
tv4fish's Avatar
Hey If it fixed the leak - leave well enuf alone ??
Old Aug 13, 2009 | 07:13 PM
  #15
Ragelite's Avatar
Does anyone out there know what I should be looking for if Im thinkin the motor mounts are bad? I know the one on the right side up across from the carb shakes wicked bad. How much movement should there be??
Old Aug 25, 2009 | 10:39 PM
  #16
brwynj's Avatar
if it is leaking at high rpm you have a vibration problem. can cause gas foam check carb boots motor mounts make sure carb is not touching frame or resting on something it shouldnt be
slowgsxr97
Mar 18, 2022 03:40 AM
GregM
Mar 6, 2018 06:53 AM
Aitch
Jul 21, 2015 09:40 PM
Unzzy66
Jul 11, 2015 10:01 PM
Robbbb55
CAN-AM (BRP) Ask an Expert!
Jul 8, 2015 02:16 PM
