97 Explorer 400 4x4 belt problems or clutch
Old Aug 11, 2009 | 05:25 PM
litjockey9353's Avatar
Default 97 Explorer 400 4x4 belt problems or clutch
I just bought this bike it seemed alright when i test drove it just a little hesitation. After i got it home and rode awhile and got it warm it revs up but dont pull, if i let of and get on throttle easy it will pull but as soon as i try to get on it engine revs and tranny quits pulling. Put new polaris belt on and same thing after it gets warmed up. Can the clutch be adjusted or am i looking at about 3-400 for a new clutch. Also is there a front and rear clutch or just the front one.
Old Aug 15, 2009 | 08:51 PM
mrtwostroke's Avatar
Well i don't have real goos explanation. but check to make sure the spring in the primary(drive) clutch isn't broken.
Old Aug 15, 2009 | 10:07 PM
eggenz7's Avatar
i would check all vent tubes for any obstructions. sounds like maybe the clutches arent getting any air ventilation to cool off and possibly causing the clutches to glaze over. after you get the belt off take some emory cloth and lightly rub the sheaves of both clutches. you might also check the secondary clutch buttons.
Old Aug 16, 2009 | 07:10 AM
ftwflh's Avatar
sounds like the secondary clutch buttons are shot.
skinnyr6
Aug 25, 2023 02:18 AM
KimSJoh
14
Jul 18, 2015 07:20 PM
honda71
Jul 12, 2015 05:56 AM
200es
Jul 10, 2015 09:09 AM
coolguy420
Jul 10, 2015 01:17 AM
