X2 500 valve adjustment.....
Howdy everyone......just turned 1500 miles on my 07 X2. The oil has been changed four times and the rest of the fluids once. It runs great. No problems what so ever. I don't like to mess with engine stuff except to maybe change a spark plug. The question is....should I or is it that important to adjust the valves?......do they normally need or go out of adjustment? Like I say it runs great and is not broken. Thanx....NoJoke
Valves
It can never hurt to check them. Didn't have to make any adjustments on my last three sp's. Asked the dealer about it on my old 05 800 back when I first bought it and they said that unless I noticed significant power loss or excessive valvetrain noise then not to worry about it(other than checking occasionally). That one ended up piped, clutched, 6" lift, 29.5", tires, and spent most of it's time WOT in the mud and never needed an adjustment.
I thought Polaris twins ( BIG BORES ) had hydraulic lifters, therefore no adjustment is possible or necessary. The valve train has zero clearance all the time .
Update.......Had the valves adjusted this last Friday by Delta PowerSports in Lathrop, CA. The service manager performed the work himself and this guy seems to know his stuff. The valves were a bit out of spec. I rode for a few miles afterward but couldn't tell any difference in performance. I'm not disappointed.....but I feel better about having it done.... I like having my X2 in tip top shape. Thanx to you all for your thoughts on this thread....NoJoke
Scooter's Shop
23
10-22-2015 07:04 PM
