Help please!!
Old Aug 17, 2009 | 06:35 PM
Big-O's Avatar
The hose is most likely a vent hose if you trace it back and then go to the parts breakdown that STENDORI sent you the link to you can see what it is. Here is just a thought, why don't you take the battery out of the one that is running and see if the motor will turn over since you know that battery is good. Again this is just my thoughts but if I had two ATVs the same model I would switch from one to the other to find what I need instead of spending $$ on what you and all of us think it might be. But if she turns over and you have good compression, fire, fuel and timing then it should run.
Old Aug 17, 2009 | 07:13 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
chances are if its a one way 50 cent piece size check valve it goes to the carb. well at least you know the engine isnt junk so thats a good start.
Old Aug 17, 2009 | 07:38 PM
jbrooks22's Avatar
funny that you mention that, the battery in the other one is bad also they have been sitting for years in a garage. I've been using the pull start to start the one that runs. So what do you guys think could be the problem with the pull start on the one that is broken? It winds up but once I put it on the atv it locks again???
Old Aug 17, 2009 | 08:12 PM
Big-O's Avatar
You can buy the whole thing on e-bay for $99.00 trail blazer 250 pull start, great deals on on eBay!
But as I said before I would get it runing with parts from the good one before I spent a lot of money on it. Just my openion.
Old Aug 18, 2009 | 09:46 AM
  #15
jbrooks22's Avatar
Well I want to thank you guys both stendori and Big-O for the help on my ATV. I switched the recoil from the 2002 to the 2000 and it worked just fine. Thank you very much so now I know I just need to replace the recoil starter, as well as the battery and the electronic starter on the 2000. I do have one more question, on the one I was having the problems with now when I put it in reverse it will not go it just makes a noise but if I hold the brake in a little bit or if I hit the power yellow button it will work just fine? Any ideas? Thanks again!
Old Aug 18, 2009 | 10:05 AM
  #16
The yellow button is a reverse override button. The quad has a safety built into it to keep it from backing up too fast. It will act like it is stalling and start bucking if you go too fast. If the button is pressed it will back up just about as fast as you want to.
Old Aug 18, 2009 | 11:04 AM
  #17
jbrooks22's Avatar
right I understood that but when I put it in reverse it does nothing but make a weird noise until I hold that button down, then it moves.
Old Aug 18, 2009 | 11:58 AM
  #18
eggenz7's Avatar
sounds like the rev limiter box is going out. does the motor start missing and sputtering? if it does pull the black wire from that rev limiter box and see what happends (be warned tho this gets rid of the rpm limiter function
Old Aug 18, 2009 | 02:00 PM
  #19
jbrooks22's Avatar
sounds good, thank you I will try that.
Old Aug 18, 2009 | 07:04 PM
  #20
Big-O's Avatar
Glad you got it running and you are very welcome. Let us know if everything works out on the override or rev limiter. Do some more searching for a pull starter, what I sent was just the first thing I found, you may even get a better deal than what I posted if you look around.
