2004 Polaris Sportsman not starting
Old Aug 24, 2009 | 09:13 AM
psjgolf's Avatar
Default 2004 Polaris Sportsman not starting
My sportsman 400 wont start. It just makes a click noise from the solenoid. I have taken off the starter and had it taken apart and tested. Looks brand new. I have put a new battery on also. I getting tired of buying stuff. Could it be the solenoid? Is there any way of testing it. I cranks fine with the pull start.
Old Aug 24, 2009 | 10:31 AM
switzomatic's Avatar
Default 400
Check your wires/connections for the battery/starter/solenoid to make sure they are tight. Could be something as simple as that. You can test the solenoid too if that doesn't fix the problem. I don't have a 400 manual so not sure what ohms to check on it. If you don't have a manual someone here should or you can ask the dealer.
UTU's Avatar
UTU
Default Starter???
Solenoid has one side battery terminal-other side goes to starter should be able to jump across see if starter works. While you had starter off did you test? RE: you could have you used a battery / jumper cables ground to starter frame-positive to starter terminal shoud spin.(HOLD STARTER) Check all connection GROUNDS!!!!
Old Aug 26, 2009 | 07:19 AM
psjgolf's Avatar
Thanks for all of your help. It was the solenoid. I did jump across the two bolts and it would crank. Picked a new one up for under $25.00.
whitty
67
Feb 24, 2021 02:52 PM
neilbedwell
Nov 10, 2018 11:02 AM
Schneider
Jun 4, 2015 11:37 AM
May 27, 2015 11:15 AM
