2003 Sportsman 500 blinking battery icon
Old Sep 2, 2009 | 05:16 AM
dmach8's Avatar
Default 2003 Sportsman 500 blinking battery icon
Recently had a roll over, quite hard i may had, it damaged the front luggage rack supports, after repairing every time you turn on the head lights you get the blinking battery icon in the guage. Its not charging at the battery, if i could get some assistance to the sequence and location of checking the system i have mechanic back ground.. You guys all helped before when the speedometer quit and the dealer wanted to change the head when it was just the sensor..
Thanks Steve
Old Sep 2, 2009 | 02:05 PM
chuck_raduenz's Avatar
so you know its not chargeing? if it is chargeing it could be a pinched headlight wire shorting out.
Old Sep 2, 2009 | 03:32 PM
dmach8's Avatar
its only putting out 12 volts out at the battery
stendori's Avatar
Super Quad Patrol
I'm watching you!
check to see if the recifier or something else got unhooked when it rolled up under the front end. just start chase wire harnesses and you should see it.
Old Sep 2, 2009 | 05:36 PM
dmach8's Avatar
Default Resolved
There was a box out by the radiator with a yellow wire that was unplugged it cured, thanks a lot..
Old Sep 2, 2009 | 07:30 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
glad it worked for ya.
Jmuddin284
Jan 19, 2026 07:16 AM
bzdok1234
30
Feb 23, 2016 01:55 PM
Gtsordo
Jul 13, 2015 10:38 PM
J-Mack
Polaris Side by Sides
Jul 4, 2015 04:19 PM
bzdok1234
Utility ATVs
Jul 3, 2015 05:32 PM
