Head light Mod
Old Sep 5, 2009 | 07:00 AM
  #21
Ragelite's Avatar
Does anyone out there have some info on doing it? does it use a relay as well?
Old Sep 5, 2009 | 07:15 AM
  #22
switzomatic's Avatar
Default Mod
Check back on the first page of this thread. I put the reverse mod instructions with the headlight mod. No relay- just two wires, connectors, and a toggle switch.
Old Sep 6, 2009 | 11:14 AM
  #23
Ragelite's Avatar
Is there a way I can do it with out the toggle? I dont want to cut into the plastic....not sure whats a better way!! I like that fact that I have to turn it on myself for saftey reasons for others riding my atv.....does this way have any side affects??
Old Sep 6, 2009 | 03:21 PM
  #24
If you just splice the two wires together it will work but then the yellow override button will not work to scroll through the speedo display functions.
Old Sep 6, 2009 | 07:06 PM
  #25
Ragelite's Avatar
How did you cut through the plastic to make it neat? Do you have any pics up? I wouldnt mind seeing where you put the toggle!!
Thanks
Old Sep 6, 2009 | 08:38 PM
  #26
I'll try and post some pics this week. If you are using a standard round toggle(what I used) then a drill bit will do it. If you get a flat toggle(like the rear work light) look on the inside of the upper headlight pod near the bottom left corner. There are some indented spots for them. Just score it with a blade until it goes through and trim to fit.
Old Sep 7, 2009 | 05:28 AM
  #27
Ragelite's Avatar
I found a nice round switch from ct that should look good. I am going to go this was as my daughter is starting to drive this more. I like the idea of the saftey of this mod.
Thanks for the good info!!!
Ill let you know next week how it turns out!
Old Sep 8, 2009 | 11:51 AM
  #28
Ragelite's Avatar
I bought a toggle and it says that there is a pin for the battery and one for the load. I would guess that the load will be the brown wire and the battery one will be the other wire you talked about??????????
Old Sep 8, 2009 | 07:10 PM
  #29
Yep. One for the ground and one for the orange/white.
Old Sep 8, 2009 | 07:22 PM
  #30
Ragelite's Avatar
Once I fix my leaking fuel tank grommet Ill be going at this project!!! I picked up all the parts tonight!
Divergent12
Dec 30, 2017 08:33 PM
bzdok1234
30
Feb 23, 2016 01:55 PM
Bulgin88
Aug 1, 2015 06:39 PM
ScopeZ_
Jul 28, 2015 01:44 AM
bzdok1234
Utility ATVs
Jul 3, 2015 05:32 PM
