Polaris 700
Old Sep 2, 2009 | 08:32 PM
woodman6703's Avatar
Default Polaris 700
I'm getting a check engine light code 46 which is barometric pressure/manifold air pressure sensor high.Can anyone tell me what this is and how to fix it.
Old Sep 2, 2009 | 08:55 PM
If its running good,no idle problem or backfiring problems,just take off battery lead for about 30 seconds and see if code comes back. If comes back,could be indicating voltage drop or spike in map sensor harness. Kits are available if you are having problems. OPT
Old Sep 7, 2009 | 07:18 AM
X2's Avatar
X2
Default Polaris 700
Check the 4 wires on the T-BAP sensor, I have had the wire connector replaced 3 times, and the last time the tech re-enforced the wires and left the harness loose allowing for engine vibration. The engine does vibrate A LOT and the wires in the connector are very small too small IMO. Next time I have an old sensor a will solder larger wires on the sensor male pins and make my own connector.
Cole Hadden
Jun 15, 2025 09:05 AM
Ramman1
Aug 11, 2022 01:53 PM
NoJoke
Aug 9, 2015 12:39 PM
Polaris Side by Sides
Jul 30, 2015 12:14 PM
maxjung
Jul 13, 2015 05:11 PM
