AWD discussion
Old Sep 8, 2009 | 09:55 PM
carlobee's Avatar
Lots of great info here. Good luck with it man. Hope all goes well.
Old Sep 9, 2009 | 08:46 PM
helmethair78's Avatar
Front diff ohms 22.8 - 25.2
Old Sep 10, 2009 | 07:35 PM
RticKwad's Avatar
Runs Stealth!
where do I put the leads on my voltage tester to? If I follow the wire down where should I test with the leads?
Thx,
R'
Old Sep 12, 2009 | 09:41 PM
trophytaker75's Avatar
You can use you display to do a service check and it will run trouble codes through a series of blinking lights you can test the hole system also thier is a seperate screen on the dash pod that will test voltages.Read your owners manual it will tell you how to run the tests through your dash pod not tools needed.
Old Sep 13, 2009 | 06:51 AM
  #15
RticKwad's Avatar
Runs Stealth!
Trophytaker75,
Have you used the POD diags, to fix this problem before or know of someone who has? FYI, I am still running my OEM battery, I haven't had any issues but if I am going to use the self diags then WHAT IF my juice isn't up to par? Could that then give me a FALSE-POSITIVE (to use that term) on low volt/ohms reading?
Please advise, thanks for the support!
R'
Old Sep 15, 2009 | 07:48 PM
  #16
RticKwad's Avatar
Runs Stealth!
Anyone?
Old Sep 17, 2009 | 06:42 AM
  #17
Thx,
R'
The wires have a plug just below the pod under the front cover. Check the side with the switch for 12v and the diff side for ohms.
Old Nov 7, 2011 | 02:23 PM
  #18
kincaidk's Avatar
Hello i have 2001 polaris sportsman 500 and when i put it in awd the front wheels won't turn. Can anyone tell me what to check and where? Thanks Kenny
Old Nov 7, 2011 | 03:16 PM
  #19
The front wheels won't kick in until the rear tires slip about 1/8 turn! Just jack up front and back with tires off the ground, crank it up in awd mode,place in gear and see if front wheels turn. If not, could be an electrical connection problem,if only one wheel turns,then could be a hub problem,hilliard or armature plate,low or no hub fluid,etc. OPT
Randy Marsh
3) General Discussions..
21
Nov 10, 2015 01:45 PM
Bigtwin700
Sep 9, 2015 09:32 AM
awer1968
Sep 8, 2015 11:02 AM
Bm400ex
Jun 22, 2015 09:16 AM
Tree Farmer
May 6, 2000 03:36 AM
