no spark
Old Sep 9, 2009 | 02:41 PM
2ndmoto's Avatar
Question no spark
I have a 2004 sportsman 500 atp that will run only if you pull start it. If you use the starter in any way it has no spark.
Old Sep 9, 2009 | 04:01 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
check the battery voltage to see what it is before you crank it and while your cranking it. chances are maybe theres not enough voltage.
Old Sep 9, 2009 | 05:58 PM
eggenz7's Avatar
the pickup coil (pulse coil) is too far away from the flywheel. starter cant spin it fast enough to excite this coil. pull start will let it excite. pull the recoil housing and check the gap. if it is within spec but still doesnt work you can pull it and elongate the two screw holes to get it closer to the flywheel. should fire right up.
fordfaithful21
Dec 7, 2015 05:52 PM
NRA+1
1) Engine problems..
10
Sep 20, 2015 08:47 PM
Cdenton
Technical and How-To Articles
Sep 9, 2015 11:23 AM
MrTrashMan2U
Sep 9, 2015 11:11 AM
jeff mc
Dunes and Dune Machines
Sep 3, 2015 07:47 PM
