What do I need to drain if I drown an EFI machine?
Old Sep 13, 2009 | 08:11 AM
tehpwnerer19's Avatar
Default What do I need to drain if I drown an EFI machine?
I have drowned many a carbed machine before, everytime I drain the carb, air box and CVT, and I'm off and running. What steps do you have to take with an EFI machine? Thanks.
Old Sep 13, 2009 | 08:21 AM
Angel of Death's Avatar
My '06 sportsman 800 was completely submerged for over an hour under ice, then flipped upside down while trying to free it.
I drained the fuel, belt box, engine oil, front diff, and rear diff.
It took something stupid like 5 engine oil changes to get the fresh oil to come out looking like oil and not milkshake, at least 3 diff oil changes for the same effect (expensive!).
Fresh fuel, fresh oil all the way around and I was good.
Hope my mistake helps.
Erik
Old Sep 13, 2009 | 09:11 AM
UTU's Avatar
UTU
You can use kerosene/diesel fuel to fill the motor and diff and drain and repeat (NOT STARTING). Then using the cheaper oil and cleaning oil filter & reusing till oil is clear. THEN use your regular oil and new filter the last time. I have filled the motor,tranny,and rear diff this way get the water out a lot quicker/cheaper(:> Need to check air cleaner/throttle body for water if motor died especially take the plugs out B4 trying to start. Turning motor over with plugs out will make sure to get water out vs motor damage if their is water in combustion chamber..............
Old Sep 13, 2009 | 09:19 AM
TLC's Avatar
TLC
Same as drowning a carb ATV,change all your fluids, the only thing different is a throttle body has no carb float bowl to drain.
Old Sep 13, 2009 | 09:36 AM
Yup, forgot to mention that! I pulled the plugs and spun it forever to get the water out.
Old Sep 14, 2009 | 11:21 AM
09 popo HO's Avatar
Sorry to piggyback your thread but I was wondering if I can use some cheap 5W30 car motor oil when trying to clean out the water rather then expensive polaris oil. I've never drowned yet but I use the word 'YET' with anticipation.
Good thread by the way, I think alot of people like me will refer to this when the time happens, Any other suggestions and tricks will deffinatly be appreciated
Old Sep 14, 2009 | 11:56 AM
gumbyman's Avatar
used the cheapest you can find.... then when all mike gone change back to your regular oil and filter.... note keep a eye on it you will more then likely have to chang it again after a few rides
Cummins Driver
Sep 11, 2019 01:22 PM
kester_holmes
Sep 10, 2015 08:27 AM
STEVE71157
Aug 29, 2015 07:33 AM
DFWSRT8
Aug 20, 2015 09:24 AM
Shifts
Jul 3, 2015 07:59 AM
