2001 Sportsman 400 Choke or carb problem
My 2001 Sportsman 400 suddenly doesn't like to start. We use it as a pit bike at the MX races. It may sit for 2 weeks and then when I try to start it, it only cranks and doesn't fire.
I have pulled off the air filter and when it cranks, gas will sputter and sometimes flow out into the air box. I have already installed a new needle and seat. If I let it set and keep trying to start it during the day, most of the time it will finally start, but maybe 3 or 4 hours after I try it the first time. Once it starts, it runs great and starts great the rest of the weekend.
The vacuum fuel pump seems fine. I am thinking it might be the choke "starting enrichment" valve. I have never worked on a carb with this, only the choke type or air restriction type valve.
How does this starting enrichment valve work? I have the service manual and the cable just looks like it has a plunger on the end. Does it inject gas straight into the carb intake?
Any suggestions?
Any suggestions?
if its the plunger style choke.... it could be sticking but its not a fuel passage it a air flow mixture.....pull it out and make sure it moves freely.... but i do agree about the carb rebuild also...
I finally got it fixed with some augguestions from my local Polaris dealer. After teraing into the carb for 4 times and everything looking good, he suggested I disconnect the magic wire to the electronics. This rules out the throttle safety switch, kill switch, speedo, etc.
Once I unplugged the wire, the engine started right up. Turned out to be the speedometer. Cleaned the contacts on both conectors and it is back running great.
UPLou
Jun 7, 2015 09:42 AM
