OK HO lets have the low down :)
#181
The reason I thought of this is because people put 3 inch spacers under the front coil in the X2, it only raises the machine, not stiffen it up.
#182
[QUOTE=Jomax;2849840]
I have a stupid question, does your 800 adjust like my XP? using the adjusters on the spring? I don't understand how that will make the ride either softer or harder, does it not just raise the spring up (and the quad with it)with out compressing it any more or less?, it would have to bottom out on the shock to change the compression? I always assumed all it would do is raise the front end up so it had more travel, as the spring doesnt have any resistance to preload against. Or do I have this all wrong??
Yes it adjusts the same way...to some extent that can lift the machine up a little the more you compress the spring,because it is lifting the spring up,which will reduce spring "sag",or the amount the spring compresses under the weight of the machine and rider. On most machines you will get a combination of raising the machine a little and compressing the spring. You can prove this to yourself by measuring the spring length at the lowest pre-load setting and the highest...it will be shorter at the highest setting...how much depends on the weight of the machine and the spring. Also take those measurements with a rider on the machine and the difference in length between the lowest pre-load and highest will likely be even more. Or even better turn the preload all the way down and ride some terrain,then turn it all the way up and you will feel the difference. Not all machines are affected the same by preload changes,different suspension set ups,(spring rates,shocks,shock angles ect)...can affect the amount of difference the preload adjustment will make. The purpose is not to raise or lower the machine,but to allow adjustability to compensate for the different weights riders and gear ect and maintain ride height and proper suspension feel. For instance if you load up the front rack you can turn up the front preload to reduce front end,diving and sag,compensating for that extra weight on the front of the machine.
The reason pre-load can affect stiffness and harsness is because the more you pre-compress the spring the more weight it takes to further compress it,even on a linear rate spring...ie on a 200 lb/in spring it takes 200 lb to compress it the first inch and additional 200 lbs of force to compress it another inch..for a total of 400 lb...that is where the added stiffness comes in. Make sense?
#183
Stiffening isn't a bad thing...there is too soft and too stiff,alot of which is personal preference.
#184
Ah yes it does make sense! And I bet if you have progressive springs (tighter coils to the top) it will make even more difference in softness when you reduce the "preload". Thankyou for thorough explanation as always!
#185
WHEWWWWWW! Seems like this discussion (BASHING) is long overdue for TOPIC CLOSED!!!!!!!!!!!
#187
must say this has been an interesting post....HO i beieve what u post is what u feel/experience. u have hands on ecperience on both machines. but u must always remember opinions are like a$$ holes!! every ones got one but some have bigger ones than others.......keep up the comparison posts. i am curious as to a long term rating on the canned ham......
#188
#189
#190
Here is a 650 can am that beats an xp 850 by just as much.
YouTube - 650 v 850
same author, do you believe this too?
Here is a video of an xp whooping up a 800r.
http://www.youtube.com/watch?v=wULDzhhX4hI
Sorry, but your just trying to stir crap up posting that video.
