Rebuilt top end-had good compression, now I don't????
Probably not what you want to hear, but you may want to assess the bottom end cost in parts, vs what the machine is worth. Tearing bottom end apart, replacing crank bearings, rod and bearing, gaskets, seals, hopefully counter balancer is good, etc, can get spendy in a hurry from your local Poo dealer
HEck-
I have no problem doing it myself- that's why I bought it. Might need a little advice here and there, but I can do it. If you do your RESERCH, you can find QUALITY parts out there for a decent price.
I got my bearings for $25(discounted), from a place that had them just sittin around for a while. Good bearings (new)
I got my rbuilt rod kit for $50 (new)
I got my seal/gasket kit top and bottom for $30 (of course new)
So, Roughly around $100
LABOR- FREE
Have the tools.
Now, I just have to put in the time. I'll getter done
LABOR- FREE
Have the tools.
#15
heck-
i have no problem doing it myself- that's why i bought it. Might need a little advice here and there, but i can do it. If you do your reserch, you can find quality parts out there for a decent price.
i got my rbuilt rod kit for $50 (new)
i got my seal/gasket kit top and bottom for $30 (of course new)
so, roughly around $100
labor- free
have the tools.
Now, i just have to put in the time. I'll getter done
labor- free
have the tools.
#16
Well-
I started at about 3 this afternoon on pulling the motor. Got it pulled, then was gonna work on it tomarrow to take off the top end and split the case. Although I was to anxious to see how the top end looked, so i pulled it off quick. Everything ended up looking good, so I was happy about that. Really interested to see what I find tomarrow on the lower end. The very suttle play is on the clutch side. Also, interested to see what the lower rod bearing looks like, there is also a little play left and right there.
ANY comments are a plus+++
Thanks!!!!
Kelly
Thanks!!!!
Kelly
#17
A few questions-
1) When I put in the new bearings, do I pack them with anything and what is a good seal for in b/w the case.
2) Since I have the motor off, is there anything I should check for on the oil pump? (or do I really have to wait until it up and running)
3) What are some other good things to check while I have the motor off?
I will deffinately do a better over view of everything myself tomarrow, but was wondering what are some things I should deffinately change out or look at while it's off.
Thanks again
Thanks again
#18
A few questions-
Thanks again
Thanks again
#19
Need some help trouble shooting- 1998 Polaris Xpress 300, 2 stroke
Just got done rebuilding the bottom end after reuilding the top end first.
Went to try and start it tonight. I had spark and compression- pretty sure I had fuel. It still made no attemp to fire up.
Any ideas????????????????????????? Puzzled
Buy the way- does anyone know the correct wiring for the stator? The last owner changed it out on there own, just wondering if it was done correctly? Would it still have spark if wires were missmatched? Just something I wanted to double check.
-The stator had one red wire and one white wire. Hooked the the red was a yellow/red wire and hooked to the white was a yellow wire I believe. The Exciting Coil had a black/red wire hooked to one side and the other side had the last remaining wire(cant remember the color off hand.
