Getting ready for winter plowing
Old Sep 25, 2009 | 04:45 PM
  #21
switzomatic's Avatar
I have a Glacier I 60" RZR blade and run synthetic cable. Have a short piece for plowing. Popo 2500# winch.
Old Sep 25, 2009 | 05:34 PM
  #22
jleo's Avatar
Originally Posted by MotorMike
Oh, one more tip: park it so that it is ready to plow! Keep the blade up a bit, so it doesn't freeze to the ground. Drop the blade and start plowing! So, you want to have it facing out, with the plow pre-positioned in the correct direction.
I disagree with the statement of keeping your plow up. I keep mine down on the ground to keep the weight of the plow off of your quad while its not in use.
MotorMike are you speaking from experience, I have never had or heard of a plow freezing to the ground. If it is a problem I would try putting cardboard or a piece of wood under the plow before I lowered it, but I definetaly would not keep the plow raised up.
Old Sep 25, 2009 | 07:03 PM
  #23
TheATVSuperStore.com's Avatar
Former Sponsor
Hand warmer and thumb warmer is a MUST!!! Don't go crazy on the blade size unless you need it. My prior was blade was 60 inch and was too large for my size driveway. I prefer going a tad smaller and making more trips. Easier to work with when you get hit hard with deep heavy snow.
Old Sep 25, 2009 | 07:48 PM
  #24
700 sportsman's Avatar
I like your new ride, I agree on the being to big sometimes, I have a Warn 54", and it's perfect for my needs
Old Oct 22, 2009 | 08:44 AM
  #25
Ragelite's Avatar
This is the plow that came with the ATV when I bought it. Anyone out there ever use one like this? I can drive up to it and it slides into place and seems to be good.
Old Oct 22, 2009 | 09:45 AM
  #26
Former Sponsor
I had one that I installed on a Honda Rubicon with some modification. Great plow!
Old Oct 22, 2009 | 09:52 AM
  #27
Ragelite's Avatar
Now I need to get some shorter winch cable or go with syn rope for the season. Princess Auto has Aircraft cable/Winch cable for $.19 a foot for 3/16. I might just do this and get about 5 feet of it.
Old Oct 22, 2009 | 02:35 PM
  #28
I just switch to synthetic, or you could do like some have, and put a short length of tow strap on the winch, and use that
Old Oct 22, 2009 | 04:40 PM
  #29
Ragelite's Avatar
tow strap eh? I have l0ts of that kicking around. Now I have never taken a winch cable off before so is there anything I should know? and how would I fasten in a tow strap so I could use it?
Old Oct 22, 2009 | 05:21 PM
  #30
well, different winches have different ways of attaching it to the spool, and usually there is a small hole that you could screw the tow strap onto the drum, but not all do
and you could try searching on here, I know it has been brought up before
