Engine Oils
Old Oct 5, 2009 | 10:09 PM
devin_01's Avatar
Question Engine Oils
Hey i was just wondering what you guys are using for engine oil in your machines?? I was thinking about maybe going to something different but not sure what i should try. All i have used is polaris oil and was wondering if there was something better than that? Thanks
Old Oct 5, 2009 | 10:45 PM
Just2Unwind's Avatar
Amsoil all the way. Have used it since 1982. They have an ATV line. AMSOIL - Synthetic Oil, Motor and Engine Oil, Lubricants, Air Filters, Oil Filters and Greases
Old Oct 6, 2009 | 03:56 AM
chuck_raduenz's Avatar
amsoil makes oil for polaris. but i use mobile 1.
Old Oct 6, 2009 | 05:57 AM
rancher55's Avatar
I just stick with the Polaris oil. It hasn't let me down yet!
Old Oct 6, 2009 | 06:28 AM
Ragelite's Avatar
For $38 to to do the front/rear diffs and tranny, why bother looking for other oils? I just did mine and all 3 fluids are not the same. And with what I have left over Im sure I can the front/rear 2 more times and the tranny once more.
Old Oct 6, 2009 | 07:50 AM
readymixer169's Avatar
Of all the things I've lost in life, I think I miss my mind the most!
mobile-1 synthetic 0w-40 for oil canges, mopar gearlube for the pigs and polaris for tranny.
Old Oct 6, 2009 | 08:34 AM
02magnum500's Avatar
Gets his share of deer.
Just stick with the Polaris brand stuff in my opinion. The Mobile one and other brands do not save you much for the engine when you are only buying 2 qts at a time. Now working with heavy equipment were it takes 11 gallons for the engine then it pays off to look around, but 2 qts isn't worth going away from Polaris brand lubricants.
Old Oct 6, 2009 | 08:39 AM
TLC's Avatar
TLC
As long as it sythetic and 0w-40 thats all that matters to me. Be it Amsoil. Polaris or Mobile 1.
Old Oct 6, 2009 | 12:40 PM
Snownut's Avatar
Default Oil
Obviously Polaris doesn't make oil, I figure they are probably using Mobil.. For me its the convenience factor.. When Im ready to change do I run to the dealer or to Autozone.. The Autozone is just down the street.. The dealer is 20 minutes away.. The thing about buying the Polaris kit is it comes with your filter, and everything you need for an oil change.
Old Oct 6, 2009 | 02:51 PM
700 sportsman's Avatar
I use polaris for the diffs. and tranny, and then I recently switched to Mobil 1 0W-40, and a Napa Gold (Wix) filter
