Belt cover noise??
Old Oct 10, 2009 | 09:24 PM
caperinmuskoka's Avatar
Ride like you own it, Not like it's stolen!
Default Belt cover noise??
Well on my 2006 Sp 450 today .....When slowing down close to idle , I hear a rattle noise comming from the belt cover?
Goes away at full idle and when increasing the throttle it's gone also??
It is only there just before slowing down all the way to a complete stop ,But not when stopped at idle.
Any ideas?
Never did take the plastic belt cover off yet to see if the are any marks on the inside housing yet......That will be my next step.....
Are the buttons (wear) on the primary?
I know on the snowmobile ckutch the wear on the secondary side.......Thanks....Caper........
Old Oct 11, 2009 | 06:38 AM
stendori's Avatar
Super Quad Patrol
I'm watching you!
i think you might have answered your own question w/ the buttons being a little worn. you know the drill, pull the cover and take a peek.
Old Oct 11, 2009 | 12:16 PM
I will take a look inside there this week sometime,Never did have the belt cover off either one of the 450's yet!!.
Now the time to inspect whats going on in there with the miles at 3000.
I will keep you posted on what I find.........Caper.
With these ATV clutch SET-up are they close to the same as a sled?
Buttons should be on the secondary?
Correct?
Old Oct 11, 2009 | 12:34 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
there are the buttons(some call them ramps) on the secondary(driven/trans. clutch) that the helix runs on which do wear out and cause a bog or maybe a shifting problem. the primary(drive/engine clutch) has buttons which are where the spider ramps slide up in down on. these are the ones that will wear and cause almost like a rattling effect.
Old Oct 11, 2009 | 06:57 PM
Yes I am used to checking and changing the Secondary ones on the snowmobile(Helix).
I guess I need a special tool to pull the primary clutch off ..Correct?
.....Caper.........
Old Oct 11, 2009 | 07:31 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
yes. you need to pull the spider off and requires specail tools. when you pull the primemary cover off, you should be able to move the spider around and see if it has alot of movement of the slides agaist the buttons.
Old Oct 11, 2009 | 08:44 PM
there must be very close tolerance between the clutch and the cover .......Even when brand new........Caper.........
Jeff Roper
Feb 1, 2022 11:48 AM
buddieboy
Dec 9, 2016 05:50 PM
mrtidy
Feb 3, 2016 05:00 PM
Ahtatu
Sep 28, 2015 12:14 PM
jbrewster94
Sep 23, 2015 04:16 PM
