Engine Swap
Old Oct 12, 2009 | 09:35 PM
95xplorer's Avatar
Default Engine Swap
I was wondering if a 1999 Xplorer 400 will swap into a 1995 Xplorer 400 without a problem.
Are they the same engine or not.
Thanks Daniel
Old Oct 12, 2009 | 10:38 PM
mrtwostroke's Avatar
two differences, the recoil cover has the handle position different. to keep it away from the pipe. and the spigot on the water pump is turned 180 degrees because the coolant line on the newer ones don't wrap under the motor beside the starter. that's all i'm aware of. oh and the cly had some design changes, no big deal either. but may require a different intake boot, because the intake flange is at a different angle.
bzdok1234
30
Feb 23, 2016 01:55 PM
toonces
Jul 28, 2015 01:58 PM
tweeder
Jul 5, 2015 01:57 PM
bzdok1234
Utility ATVs
Jul 3, 2015 05:32 PM
