problems with a 1993 350l
Old Oct 15, 2009 | 09:34 PM
tw1st3d1's Avatar
Default problems with a 1993 350l
I had the machine idiling, and it backfired. after that it was almost impossible to get started. I figured that it was a blown out crank shift seal. I checked the clutch side first, and it seems fine. I looked at the outer seal on the flywheel side and it looked good. I started to take the bolts out of the crankcase from behind the flywheel, and a milky substance started oozing out of the bottom bolt holes. I figure it is coming from a bad water pump seal. but where is it mixing with oil from? and if the 2 outer crankcase seals being in good shape, what is causing the hard start?
Any help would be really appreciated.
ogio117
Polaris Side by Sides
Apr 29, 2019 03:14 PM
cornermike
Jul 30, 2015 06:37 AM
ScopeZ_
Jul 28, 2015 01:44 AM
Ty64
Technical and How-To Articles
Jul 25, 2015 02:02 PM
hondarider1234
Jul 21, 2015 11:53 PM
