2002 sportsman 500 h.o. stator problem
Old Oct 19, 2009 | 12:07 PM
sk8er289's Avatar
Default 2002 sportsman 500 h.o. stator problem
my batterie keeps dyin and the stator wont keep in charged. i took the over off where the stator, now i dont know how to take the flywheel off, i think theres a tool but no totally sure. and also my awd is messed up i think, the front cv axles spin but the tires dont.
Old Oct 19, 2009 | 01:28 PM
Have your battery load tested for a bad cell,if its a new battery check that you are getting around 14-14.5 volts with a volt meter when above idle. If still not charging check that all 4 connectors at regulator/rectifier at front left of machine have good connection. Most of the time charging problems are reg/rectifier related,bad/poorly ground connections at battery,etc. Can be the stator,but check these out first. Awd system is electric and mechanical,must have 12 volts to work. If battery is bad/not charging,awd wont work! OPT
Old Oct 19, 2009 | 01:43 PM
sk8er289's Avatar
o got ya, i already bought a new stator and rectifier. im have no clue how to get the flywheel off. how do you know if there is a bad ground
Old Mar 3, 2010 | 05:06 PM
bschreib's Avatar
Did you have any luch getting the flywheel off? I am having the same issue.
Old Mar 7, 2010 | 09:59 PM
sk8er289's Avatar
ya it was a pain. i had to use a regurlar car puller. had to spray it to make it loose and let it sit over night.
Old Mar 9, 2010 | 09:50 AM
bschreib's Avatar
Thanks, same thing for me, it took a car puller, quite a few bent bolts and washers, and a lot or effort. But it eventually came off.
Thanks
skittero
35
Mar 1, 2019 12:39 AM
AtvManiac78
Jul 11, 2015 03:20 AM
gfl0224
Jun 27, 2015 06:52 PM
mudhog
Nov 2, 2000 06:22 PM
