Get rid of these scratches on my fenders!!!!! HELP!!!
Is there any thing that takes scratches away on the fenders besides amroall or any other protechtant. I herd gasoline works will that hurt the fender and how do you put it on does it work good?????????
thanks for any info
HAVE A NICE DAY
thanks for any info
HAVE A NICE DAY
thers only one thing i heard of that takes out scratches(not sure of its name)..its a sanding process you start with a rough grit and work your way to a fine grit paper..i have also heard if you do it you have to do the whole process which is alot of work..personally i dont think its worth it..if you own a quad its going to get scratched unless you dont use it
It's called PC racing plastic renew, it cost about $18 bucks. I've used it on my scrambler, you start off with the sand paper to sand down the scratches then apply even coats of the plastic renew formula. It comes out like near showroom.
You can find it in most dirt bike and atv catalogs or ask your dealer.
2000 SCRAMBLER 400 2X4
SCRAMDADDY400
SCRAMDADDY400
