Leaking oil??/
Old Oct 24, 2009 | 03:23 PM
Ragelite's Avatar
Default Leaking oil??/
Ok so about 2 months ago I changed the water pump and I the only thing I didnt change was the gasket and I just noticed that there was a little fresh oil dripping from around the pump so i wiped it up but it looks like its been doing this for a few weeks. Its the only place that looks like this, take a look at the pic and let me know what you guys think.
thanks
Old Oct 24, 2009 | 03:30 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
did the gasket get ripped or distored causing it not to seal. bolts i'm assuming are tight? just wondering if it will get worse and you will have to fix the leak before something esle happens. just a thought
Old Oct 24, 2009 | 04:06 PM
Ragelite's Avatar
Does anyone know what that seal is behind the weap hole? I think thats the seal thats leaking!
Old Oct 24, 2009 | 05:30 PM
gaspumpcity's Avatar
In the picture it looks like the oil starts leaking up higher to the left.Do you have excess to a black light this might give you a better look where it is leaking oil.
Old Oct 24, 2009 | 06:46 PM
If you didnt change the oil seal behind the waterpump seal could possibly be the problem.The weep hole is a center spot for coolant and oil indication if either seal is bad. Sometimes hard to see oil leaking when waterpump seal is bad also. OPT
Old Oct 24, 2009 | 07:52 PM
4getful2's Avatar
i thought you had to split the case for the oil seal deal. does the case have a crack in it??
Old Oct 24, 2009 | 10:00 PM
TLC's Avatar
TLC
not on the 500 http://www.atvtime.com/phpBB2/viewto...6762c0e8c2fe2e
Old Oct 25, 2009 | 12:56 AM
Lot of good this post did to many photo bucket delete!
Old Oct 25, 2009 | 07:36 AM
TLC's Avatar
TLC
You have to hit his top photo bucket link . Here you go http://s470.photobucket.com/albums/rr68/cortexans/
Old Oct 25, 2009 | 08:45 AM
Ragelite's Avatar
What you are seeing up higher is just grease thats come off the drive shaft and has splattered around.
exmotocrosser
Sep 13, 2019 06:12 AM
1ArmBandit
55
Oct 14, 2015 09:03 PM
Scooter's Shop
Oct 9, 2015 02:09 PM
wrencher82
Sep 24, 2015 03:39 PM
bvolks
Sep 13, 2015 12:57 PM
