1997 Sportsman 500
Old Oct 26, 2009 | 09:56 PM
devin_01's Avatar
Question 1997 Sportsman 500
I cant seem to get my quad to fire up. It has fuel and spark but it looks weak. What tests should a guy do or does something just need to be cleaned.
Thanks Devin
Old Oct 27, 2009 | 05:00 AM
stendori's Avatar
Super Quad Patrol
I'm watching you!
did you try changing the plug? is it fouled,wet,dry? is the air filter plugged? just start w/ the basic checks first and go from there.
Old Oct 27, 2009 | 11:15 AM
TLC's Avatar
TLC
Behind the recoil is a pulse coil,make sure its face is clean ,its magnetic and picks up lots of crud after awhile. A good sign of it needing to be gaped or cleaned is the ATV will not start with electric start yet starts up with the pull start.
Old Oct 27, 2009 | 01:02 PM
devin_01's Avatar
Ya ill check that stuff out. If there is anything else i should be looking at let me know. Ill let you know what i find.
Thanks Devin
Old Oct 27, 2009 | 06:53 PM
devin_01's Avatar
what should the gap be on the pulse coil?
Old Oct 27, 2009 | 09:55 PM
devin_01's Avatar
plug is good, air filter is good, but the spark looks weak. I cleaned the pulse coil and the flywheel but its still having a hard time starting. The plug is coming out damp. Maybe its a carburator issue?? Kinda at a stand still at the moment. Any help or suggestons would be great.
Thanks Devin
Old Oct 28, 2009 | 08:17 PM
devin_01's Avatar
Anyone?
Old Oct 28, 2009 | 11:00 PM
devin_01's Avatar
Never mind it ended up being the spark plug wire was half bad. Put the one off the other quad and runs great. I guess thats why the spark looked so week.
Old Oct 29, 2009 | 01:22 AM
carlobee's Avatar
oh. good to know you figured that one out. enjoy your quad
Old Oct 29, 2009 | 04:25 AM
stendori's Avatar
Super Quad Patrol
I'm watching you!
a cracked or bad wire/cap will do that for sure and will act up when it gtes wet as well. good find and fix.
