added plow weight and breaking the cable
I was reading another thread "New Wear Bar" posted by rr-john where He had used a heavy cutting edge and made His own and it reminded Me of My sons plow.
he added a lot of weight,maby 70 to 80 pounds to His plow to hold it down and He is always having to rebuild His cable end due to fraying.
has anyone else here had this problem and what did You do to fix the problem???
Why couldnt you just spool the cable on backwards? The cable spools under the winch spool. If you unwound all the cable and pushed "out" and spooled it back in then the cable would be coming off the top of the spool thus lessening the angle the cable is bent. I cant think of a reason why it would hurt the winch.
i think switching from steel to synthetic and pulling from the top of the spool will help.
I did a lot of plowing with my wheeler and would have to repair the frays a couple times a year, with no extra weight on the plow system. Just a lof of use and the roller would sometimes freeze up and not move as freely as it should in the cold snow. I never found a good fix, tried the rope extension but same issue.
Sooo,It does look like the roller on the plow fair lead has a bigger diameter than a standard fairlead.That would probably help a lot.
craacker
09-09-2015 04:32 AM
