97 sportsman 400 counter balance fluid
Old Nov 16, 2009 | 02:29 PM
broke down's Avatar
Question 97 sportsman 400 counter balance fluid
The fluid is milky, i need to replace with 30 weight oil right? where is the drain plug?
Old Nov 16, 2009 | 04:16 PM
4getful2's Avatar
hopefully you submerged it . i hope it's not antifreeze
Old Nov 17, 2009 | 07:19 AM
uncertifiedmechanic's Avatar
My home made pliers did get the job too.
You might have to get into the counter balancer and replace seals, normally "milky" means antifreeze is getting by. But in any case the plug should be in the middle underneath, and have a phillips head and or 10mm/3/8" head
Old Nov 17, 2009 | 08:41 AM
broke down's Avatar
oh man i was hoping I was just missing something. I pulled that one first and clean green antifreeze came out. I was hoping that was part of the water jacket/cooling system. I need a service manual. Are there any free downloads for one.
Old Nov 17, 2009 | 10:43 AM
GIGEM18's Avatar
Default No free manuel i can find
Read my post 2000 scrambler 400 leaking antifreeze.. I am in the process of doing the same repairs on mine. W/p is leaking into cb and crankcase. Parts for mine should be here soon and i will let you know how hard it was.. Pulling apart was not that bad. Good luck
robert301972robert
Aug 30, 2015 11:34 AM
Polaris5
Aug 29, 2015 09:11 PM
Stirling
Aug 9, 2015 01:49 PM
rjacree
1) Engine problems..
Aug 3, 2015 10:21 AM
rcappie4
Jul 10, 2015 04:54 PM
