Found the Gas Leak-Bottom Tank Gromet!
Old Nov 18, 2009 | 07:01 PM
weedy's Avatar
'5 minutes worth of planning equals 30 minutes of execution'
Angry Found the Gas Leak-Bottom Tank Gromet!
Have been smelling gas when storing my wife's 2004 SP500. Found a gromet in the bottom of the tank to be worn out and leaking.
Anyone else see this with their machines?
Old Nov 18, 2009 | 08:08 PM
Had a recall on grommets when first used several years back,but havent had any problems about em since then. But as the old saying goes: Anything man makes can and will break! Hopefully just a freak thing and hopefully not many others have the same thing happening! I dont need any more recalls! Have quite enough of em right now! OPT
Old Nov 18, 2009 | 09:18 PM
weedy's Avatar
**** poor design but it did last 5 years. My 05 has a bolt on fitting on the botom of the tank which makes alot more sence.
I am guessing the old gromet just presses in the bottom hole of the tank and the metal fitting goes in after the gromet is installed in the tank?
That tank was a bear to get out!
Old Nov 19, 2009 | 08:33 PM
weedy's Avatar
Repair completed. This seems o be a common proble with the older SPs. Cheap $10 fix.
Cummins Driver
Sep 11, 2019 01:22 PM
Jazperman
Aug 7, 2016 08:12 PM
Ronk407NY
Feb 13, 2016 11:05 AM
Aitch
Jul 21, 2015 09:40 PM
Shifts
Jul 3, 2015 07:59 AM
