Best method to drill hole in plastic
Old Jan 10, 2010 | 10:38 AM
Padraic's Avatar
I just did mine with a spade/butterfly bit. Exact size and clean hole.
Old Jan 10, 2010 | 12:24 PM
FunRide's Avatar
A hole saw of the proper size will give you the cleanest hole in the plastic.....
Moose...Only hole saw I've seen is the big ones that you use to drill a clean hole for a dryer, say 3 1/2" bore? I've seen smaller ones for drilling through wood for electrical, but they're huge 1/2" chuck angle drills.....not sure what you mean.
I've got both the thumb warmers and the grip warmers in my lap at the moment. Timely info.
Old Jan 10, 2010 | 01:46 PM
700 sportsman's Avatar
they look just like a big hole sawy, just mini, like these:
Hole Saw Kits
Old Jan 10, 2010 | 04:17 PM
700 Sportsman hit it on the head. There are smaller bores. I generally used them installing locksets in doors. The bi-metal hole saws will even cut through a steel door with patience. A spade bit can be bad in thin material and make a rounded triangular hole. A forstner bit would be a better second choice over the spade bit. Both the hole saw and forstner are designed to cut sharp clean holes.
Old Jan 10, 2010 | 05:28 PM
  #15
FunRide's Avatar
700 Sportsman hit it on the head. There are smaller bores......
Got cha...Didn't realize they made them that small.
Old Jan 10, 2010 | 05:37 PM
  #16
FunRide's Avatar
Originally Posted by 09 popo HO
I installed some hand and thumb warmers on my sportsman but I'm nervous about drilling holes for the switches.
Not to change the subject too much, but I've got a nice set of heated grips waiting to be installed. Wish they were installed today boy,.......cold. They're Moose grips that have a little rocker switch (round). Also have a stick-on thumb warmer for the throttle; however the thumb switch, which is also made by Moose, is square and looks like something from the 1940s. I'm wondering if anybody knows of any rocker switches that I could mount in the plastic that match, and may be a bit higher quality. The round one is OK, but still on the cheap side. Any ideas....or anybody else swap theirs out?
Old Jan 10, 2010 | 06:31 PM
  #17
stendori's Avatar
Super Quad Patrol
I'm watching you!
just make sure they will handle the power that goes thru them w/out burnig then out. you could go to an auto parts store and get a good quailty one that might be what your looking for. just a thought
Old Jan 10, 2010 | 06:48 PM
  #18
coyote170's Avatar
Talking
X3 works for me to!!!
Old Jan 10, 2010 | 07:55 PM
  #19
FunRide's Avatar
Huhhh??
Old Jan 10, 2010 | 08:24 PM
  #20
Big-O's Avatar
just a thought but I would go to the local boat dealer and get marine grade switches. they are more $$ but will hold up in the weather where automotive will not. The Bass and Saltwater boat places sell high amp/volt switches for all sorts of applications. Again they will cost more but they should last the life of the ATV.
