instrument cluster not working
Old Jan 9, 2010 | 12:26 PM
GMD's Avatar
GMD
Default instrument cluster not working
Hi,
2004 Sportsman 500. The instrument cluster stopped working. It is completely dark. When you start it up turning the key on doesn't light anything up. The manual says this can be caused by a battery overvoltage. Is there a way to determine if this was the cause? I have thought about disconnecting the battery to see if it would start working again.
Thanks for any help
Old Jan 9, 2010 | 12:52 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
welcome. you shouldn't unhook the battery as it might do more damage w/ no battery to recieve the volage the bike is putting out. did you pull the pod apart to check the big wire connection on the back of the speedo? also if you had a voltage tester you could test the battery w/ the bike running to see how many volts it is while reved to about 3,000. it should read around 13.7 to 14.5 depending on the battery charge.
Old Jan 9, 2010 | 05:59 PM
GMD's Avatar
GMD
I didn't mean I'd leave the battery disconnected. If it was shutdown due to some problem...If I unhook the battery and leave it a few minutes. Then hook it back up...if it works then if there is a problem it should shut down again.
No I have not really looked into it at all yet. It was extremely cold today...supposed to back up in the 30's next week so I'll start looking at it then. Not a bike by the way but an ATV.
thanks for your help
hugemoth
Jul 20, 2020 03:28 AM
KimSJoh
14
Jul 18, 2015 07:20 PM
timster911
Jul 13, 2015 01:57 PM
J-Mack
Polaris Side by Sides
Jul 4, 2015 04:19 PM
bikedad3
Jul 2, 2015 02:15 AM
