03 magnum 330- Need plastic, and would like an aftermarket exhaust....
Old Jan 14, 2010 | 05:42 AM
chevyaddict83's Avatar
Default 03 magnum 330- Need plastic, and would like an aftermarket exhaust....
03 magnum 330. Would like to find some aftermarket plastic, namely all the body work, without going thru the dealer. Any idea if any other model plastic fits? Also, want a little more bark out of her, and I was wondering if there are any slip on exhausts? Thanks for your time.
Old Jan 14, 2010 | 05:59 AM
ftwflh's Avatar
on the exhaust call RcR they have a power kit for the 330/325s
Any GENIV plastic will work.Like 500/400 Sportsman,325/330 Magnum,400/300Xpress,400 Xplorer.The 2stroke models will have a oil hole in the front hood.
Old Jan 14, 2010 | 06:31 AM
now on the plastic, does the 2wd versions work too? and what years are the genIV?
And lastly, does rcr have a website?
Old Jan 14, 2010 | 02:44 PM
readymixer169's Avatar
Of all the things I've lost in life, I think I miss my mind the most!
I believe ftwflh is referring to (RcR) Ritter Cycle Racing and yes they do have a website but you'll be better off to call and speak with them. They'll hook you up with what ya need. Good people. On your plastic I think but not for sure on the years, anything from 03 down into the mid to late 90's should fit 2wd or 4wd however there were some subtle differences in the bumpers on certian years which I don't think affects the body components. Can anyone else confirm or deny this.
Old Jan 14, 2010 | 02:51 PM
scootergptx's Avatar
Supersock
Hired Gun!
Ritter Cycle
But like Readymixer said, it's best to call him. He just gets too busy to answer all his calls.
Put the stage one on my old trail boss. Didn't make it a rocket, but it sure did give it some low end grunt. And just sounded a whole lot better.
Don't think you'll find a company that has better service.
Joe454
Nov 20, 2020 01:19 PM
EIF
Apr 20, 2017 07:15 PM
Gwolf228
Feb 18, 2017 01:36 AM
Quadzilla Heritage
Sep 25, 2015 01:39 PM
cboler9
Sep 24, 2015 08:35 PM
