Clearing diagnostic codes
Old Jan 28, 2010 | 11:19 AM
stendori's Avatar
Super Quad Patrol
I'm watching you!
Originally Posted by 06Sportsman
It is the EFI codes that do not seem to clear It Has 45, 46 and 55.
here are the codes=45,46 are barometric pressure/manifold air pressure sensor low and high(45 is low and 46 is high) and 55=MIl circuitpen load or shorted load/short to ground or battery. didn't see anything in the service manual on deleting codes except it says dealers are able to read the codes and what they mean.
Old Jan 28, 2010 | 02:35 PM
06Sportsman's Avatar
Default Clearing codes
thank you stendori. I Have a Clymer's repair manual with all the codes. The manual say's to disconnect the positive battery cable for 20 seconds to clear codes but that does not seem to work.
Old Jan 28, 2010 | 06:14 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
if unhooking the battery doesn't work after say a cuple of minutes then i would say the dealer might be right. see what it says about the fix for the bad codes. i didn't go that far to see a test or fix for it.
Old Jan 29, 2010 | 08:41 AM
caperinmuskoka's Avatar
Ride like you own it, Not like it's stolen!
Are you sure they are the olny ones to clear the code?
There are many people on here that can do great stuff.....
.......caper.......
Old Jan 29, 2010 | 05:39 PM
  #15
Big-O's Avatar
You will have to fix the problem before the codes will cleare if it is like a car. If you do not fix the problem/bad sensor, as soon as you hook the battery back up the sensor will just send the same code back to the computer and it will keep doing that until the problem/bad sensor is fixed. I should have been clearer when I replied the first time. My Bad. As I said before I am not an expert on the computer system for an ATV but I turned wrenches for a living for about 8 years on cars in the 80,s and I am guessing that it is not that different.
To make it short as long as there is a problem you will not be able to clear the codes.
Hope this will help. If not you might want to PM one of the guys on here that work at the dealerships and see what they have to say. Just a thought.
speedbuff
13
Nov 11, 2020 10:16 AM
2many2ride
Sep 27, 2015 04:35 AM
Sw00p
Sep 24, 2015 02:50 PM
patrick.oc123
Sep 16, 2015 03:45 AM
patrick.oc123
Sep 15, 2015 02:45 PM
