what wheels and backspace is needed
Old Feb 4, 2010 | 07:06 PM
cornicejumper's Avatar
Default what wheels and backspace is needed
Wanting to put 27 x12x12 on all four corners of my 09 650 xt outlander for my gf in the snow but im not sure what wheel and backspacing i need to make this work and the same question for an 09 sportsman xp 850 but im gonna put 28 x12x14s on it... anybody with any info on doing this to either of these would be appreciated
Old Feb 4, 2010 | 09:44 PM
Big-O's Avatar
I can't give you any advice on offset or spacing. But I will say in my opinion you should keep the front tiers closer to stock width. The whole design in mud/snow/dirt/gravel is for the front tires to cut in and not float so you have more control. So unless you are going to use these ATVs for mud pits or something other than normal use you should rethink your tire sizes.
Old Feb 5, 2010 | 09:27 AM
I understand what your saying but thats the whole point in going wide in the front so they dont cut in and u do float when your running around in 5 feet of snow front tires cutting in = getting stuck if the fronts float like the rears then its not that much of an issue
jrooker6
Ask the Editor
11
Apr 21, 2016 07:35 PM
Mphillips
Jul 29, 2015 08:53 PM
Stillonit
Jun 18, 2015 11:23 AM
volsgo30
Jun 4, 2015 06:07 PM
