Lock-N-Ride mounts?
think thats the guy i got mine from. i was gona use bilge plugs. but there not long enough to go though my 3/4" plywood for my sparyer base/mount.
the only way you can build them is find the latch, and the thick rubber washer. the rest would be the easy part. the bolt depends on how long you need but (cut off the head and drill a hole so that the small machine screw can be used to hold the latch on) shown on the second pic i provided above, a washer, and a nylock nut.
#17
as for a stock photo. i dont have any. but just take the 3 white washers out, the fender washer (silver one just bellow the black washer) and its back to stock. and the bolts in the second pic are the stock bolts. i had to make new bolts so it was longer to fit though a 3/4" sheet of plywood. if you want the bolts there for sale. oh and there metric.
good luck....
good luck....
#18
Thanx Chuck Raduenz, time to go to Shaw Plugs they have a lot to offer xspecially custom which is nice........................................
slimey
slimey
